Hi team!
I am setting up my Raspad with Raspberry Pi OS Bullseye (64-bit) and trying to set up the auto-rotator. I did have this working well on the same device with Raspberry Pi OS buster (32-bit).
I followed the instructions at https://docs.raspad.com/en/latest/install_rotating_screen_service.html and the `install.py` script ran without any errors, but the auto-rotate did not start working or prompt me to reboot.
I tried rebotting and rotated the screen slowly as per the directions, but when I run `raspad-auto-rotator reset` I get the following error:
File "/usr/local/bin/raspad-auto-rotator", line 15, in <module>
sensor = Sh3001(db=CONFIG_FILE)
File "/usr/local/lib/python3.9/dist-packages/sh3001-0.0.1-py3.9.egg/sh3001/sh3001.py", line 391, in __init__
super().__init__()
File "/usr/local/lib/python3.9/dist-packages/sh3001-0.0.1-py3.9.egg/sh3001/i2c.py", line 12, in __init__
self._smbus = SMBus(self._bus)
FileNotFoundError: [Errno 2] No such file or directory
I get the same error when trying to run the `debug` command as well. When I looked at `~/.raspad-auto-rotator/config`, there is nothing there. I'm not sure if an error handler is missed in the `install.py` or if I have something set up wrong.
Other parts of setting up are going very smoothly. I tend to use the Raspad in portrait view when reading blogs and would like to still use it that way.
