I followed instruction on:
https://github.com/sunfounder/raspad3/blob/main/docs/source/install_rotating_screen_service.rst
and I still can not ratate screen of raspad:
After executing command:
git clone https://github.com/raspad-tablet/raspad-auto-rotator
cd raspad-auto-rotator
It installed that but I get no reation form screen after rotation.
I tried:
raspad-auto-rotator reset
but no raspad-auto-rotator command exist and even then I go and try from directiory by:
./raspad-auto-rotator reset
its very hard to help with this as you havent provide any output of the install command so i cant see if there was any errors, so do 2 commands for me to be better able to help you.
run
sudo i2cdetect -y 1
paste the output here. then run the install script again and paste the output of that too then i may have a better chance of helping you.
also to make mine and your life easier, open the back of the raspad3 and post a picture of the inside so i can heck you have it all connected correctly.
BEFORE:
pi@raspberrypi:~ $ sudo i2cdetect -y 1
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
AFTER:
pi@raspberrypi:~ $ git clone https://github.com/raspad-tablet/raspad-auto-rotator
fatal: docelowa ścieżka „raspad-auto-rotator” już istnieje i nie jest pustym katalogiem.
Installing RasPad auto rotator
Install dependency
[ OK ] update apt...
[ OK ] install i2c-tools...
[ OK ] install pip...
[ OK ] install xinput...
[ OK ] install setuptools...
Setup raspad-auto-rotator service
[ OK ] copy raspad-auto-rotator file...
[ OK ] add excutable mode for raspad-auto-rotator...
[ OK ] copy rotate-helper file...
[ OK ] add excutable mode for rotate-helper...
[ OK ] copy autostart...
[ OK ] Get SH3001 library...
Install sh3001 python package
[ OK ] run setup file...
[ OK ] Start auto rotator...
Installation finished!
pi@raspberrypi:~/raspad-auto-rotator $ sudo i2cdetect -y 1
I attach photo in next post.
Go to Menu > Preferences > Raspberry Pi Configuration and then go to interfaces tab and enable I2C
Thank you very much. It is working.
no problem, happy to see you got it working.
