Has anyone found documentation on how to update standard Raspian OS for the Raspad 3? I'd like to use mine for a portable SDR (software defined radio) and am using a build pre-loaded with Amature Radio specific software (HamPi). It is built on a standard Raspian OS. I'd like to add back in auto-rotation and cooling fan controls along with all the other goodies that RasPad offers. Are there instructions somewhere? Thx!
        So, I found the raspad-launcher github (https://github.com/raspad-tablet/raspad-launcher/blob/main/docs/installation-guide.md). It looks like what I was looking for, but I get the following error when I install it:
pi@hampi:~/raspad-launcher $ sudo ./install
RasPad Launcher install process starts
[ OK ] Update apt...
[ OK ] Install dependencies...
Install RasPad Launcher
[ OK ] Copy raspad-faq.desktop...
[ OK ] Copy raspad-launcher.desktop...
[ OK ] Copy icon...
[ OK ] Copy raspad-launcher...
[ OK ] Copy raspad-launcher-helper...
[ OK ] Add excute permission...
[ OK ] cp panel settings...
[ OK ] change panel setting owner...
[ OK ] replace menu icon...
[    ] Reflash panel...[Fail]
Install screen auto rotator
[ OK ] Clone package...
[ OK ] Install python-sh3001...
[ OK ] Enable auto rotate...
Reflash panel error:
  Status:1
  Error:No protocol specified
Cant connect to display: :0
Has anyone found a solution? Thanks again!
        @Dave R Have you executed it on the desktop or in vnc?
        Thank you for your time. This was done from the desktop. Is there a way to turn off the Raspad GUI and return it to native configuration? I was hoping the launcher would update the icons to be more touch screen friendly, but instead it replaced the original menu with Raspad menu.
